ATI X850XT power supply question
holycpu
Is the following power supply good enough for X850XT ? Thank you
Specifications
Dimensions: 150mm x 86mm x 140mm
Connectors: 8 molex (4-pin), 2 floppy, 2 S-ATA
Input: 95~264V @ 50~60 Hz
Output: 520W
3.3V - 32.0A
5.0V - 36.0A
12.0V - 28.0A
<5% Load Regulation
<1% Line Regulation
Efficiency: 75% under load
Over Voltage Protection: 3.3V/4V 5V/6V 12V/14V
Over Power Protection: 105%~150% of max load
Looks good.......... I run my System with an OCZ 420 which specs out very similar to that one....
