ati x800xt texture problem!! plz help (pics)
hmmyah
Im getting some weird stuff with my x800xt.
FarCry 1.2 patch 1600by1200 2x aa 2x af
COMMENT: i couldn't get a good pic sorry i was in a rush, but there were some where 90% of the ground lost texture.
Generals (i believe the latest patch) 12by10 res
COMMENT: you can see the shadows were tearing.
Counter-Strike 1.6 1600by1200
COMMENT: i get something like this in a couple maps, but its usually only in one or two spots like on this maps, the only place it was doing it was on the staircase.
Some Info:
a. I reinstalled my drivers to make sure they were installed correctly. (cats 4.7)
b. This x800 is not overclocked and never has been overclocked.
Is anyone else having this same problem?
The CS Issue is usually a map fault, I saw that back when I was on a Voodoo3 in HL. Its poorly made maps, your probaly just noticing it now. Two burshes are overlapping...
The Farcry texture issue is also a problem brought on by the 1.2 patch I believe...
You think that is bad? Try playing City of Heroes with an ATI card.
The textures flash so terribly they will put the most robust players into seizures.
ATI has documented the COH issue.
I don't think it's the card, but the drivers. You can check known issues at ATI's wesite.
:mad: :confused: :mad:
I got the card from the compusa in mesquite, texas.
Glad to hear that its probably only a driver problem. :me prays: :D
