Looks like we have new reigning champ(s)! ATI FTW!!
http://www.dailytech.com/article.aspx?newsid=3727
Could Nvidia's GX2 video drivers not be optimized (or the othe way around, the games not being optimized) for quad yet? I wonder if these benches are with the new forcewares..
Radeon X1950 CrossFire puts Quad SLI in its place
DailyTech has received early benchmarks of ATIs upcoming Radeon X1950XTX and X1950 CrossFire graphics cards. ATIs upcoming Radeon X1950XTX and X1950 CrossFire is expected to make its debut on August 23rd. Specifications for the Radeon X1950XTX and X1950 CrossFire are finalized with a 650 MHz core clock and 2 GHz effective memory clock. The core clock is unchanged from the previous Radeon X1900XTX while memory clock receives a hefty 450 MHz boost. This time around the Radeon X1950XTX and X1950 CrossFire are equipped with 90nm Samsung GDDR4 memory.
The benchmarks compare ATIs Radeon X1950XT in CrossFire against NVIDIAs Quad SLI. The test setup used for NVIDIAs Quad SLI is a Dell XPS 700 system equipped with an Intel Core 2 Extreme X6800, 1GB of DDR2-800 memory and two GeForce 7950GX2 graphics cards for four total GPUs. The ATI CrossFire test system is identical with the Quad SLI system except the nForce 590 SLI Intel Edition motherboard was swapped out for an early Radeon Xpress 3200 (RD600) motherboard and two ATI Radeon X1950XTX/CrossFire graphics cards.
These early benchmarks are favorable to ATI. Call of Duty 2, Half-Life 2: Episode 1 and Serious Sam II heavily favor ATI, most likely due to better multi-GPU scaling on ATIs side. FarCry, Quake 4 and Doom 3 performance shows the Quad SLI system creeping up to the performance of ATIs X1950XTX/CrossFire system. However, the Quad SLI system still falls behind, close but no cigar. F.E.A.R. is the only game that can take advantage of Quad SLI and shows the Quad SLI system beating out the similarly configured X1950XTX/CrossFire system; though at 2560x1600 with 4xAA and 8xAF the X1950XTX/CrossFire takes the lead once again. With Elder Scrolls IV: Oblivion the X1950XTX/CrossFire system manages to take a nice lead over Quad SLI at 1600x1200 with 8xAF. The lead narrows when the resolution is raised to 2560x1600 with 8xAF.
