Ok so I am putting together a dualboot win7/ hackintosh and I need some help.
I am going to run a 3 monitor setup PLP using the 3007 and two 2007's as bookends.
Recently I have found out that neither cards will support my display setup. Unless I use softh. I may use softth from time to time just to experience it. Hopfully sometime down the road either one will support PLP.
So if I can't game across all three, then I want to max out the capabilites of my 30 incher.
What do you guys advise for running games at 2560x1600?
I have spken to my builder and he has said the gtx cards are currently not supported with osx. He also said there is a software update comming soon that may fix this.
Up untill now I was set on two msi gtx 470 cards.
But with them not being supported and having to wait for this software fix. I'm starting to lean twd the ati cards. Problem is I have done so much reasearch on the gtx cards that I'm brainwashed by it.
Does the nvidia cards beat out the ati cards enough for me to wait for the gtx cards to be supported?
Running at 2560x1600 does this force me into ati cards due to the higher vraM?
Any advice would be great as my builder has all the rest of my parts ready and is jut waiting on my video card choice.
Sorry for the typos I'm sending this from my droid.
