ATI TV Wonder Pro trouble
sysoad
I bought a TV Wonder Pro about two months ago and the picture lags after the sound. I hear somthing before I see it. This is the case with both composite video and antenna cable. System specs below.
Athlon XP 2100 | ABIT NF7 | 512MB DDR266 | GeForce FX5900 | 120GB WDJB
Any help would be appreciated.
There are probably 2 problems with your setup.
If you are using onboard sound...don't. If you are using a SB Live, update the drivers.
Also updtae your video drivers.
I had the same problem with my AIW, and that fixed the problem.
I know somebody who is having the same problem, I'll keep you posted on any results ;)
