ATI tray tools problem
socK
This just started happening today when I started the computer. I get Unable to retrieve BIOS information bla bla something. Nothing has changed, I tried reinstalling the program, nothing.
x1950xtx on 7.1 drivers. It works if I disable overclocking, but then I can't screw with the fan speeds, which is what is basically what I want to use it for. It's been running fine for months and just now it decided to shit itself. :confused:
Cleaned everything, updated drivers, reinstalled ATT, and it starts up no problem now, but it says No supported hardware in the fan control. How can that be when it was working before no problem? I'm pretty sure I have the newest version of it.
Also going to state to set it to driver level under settings/X1000 compatibility.
