Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I read it somewhere on a forum where someone had tested it. Said something similar to: 'fix for the XT voltage'
I'll see if I can find that info again.....but really can't remember where I saw it!!!! All I can say for now is that it definitely fixes the RAM issue as it no longer goes beserk and/or crashes when you try to overclock the RAM.
Edit: This is what I found (but not the exact same post) and is relaease 1.2.6.977 "The reason being is that this version has fixes specicially for the X1950 series of cards. ATT now detects the ram speeds correctly, so it no longer craps out when you adjust the clock rates. There are also other fixes for the series, including a database update for some Advanced Tweaks, updated overclocking support, and some test voltage regulation support for the X1950XT."
Whenever Ray updates the beta he updates the file in that link, so you will always get the most recent beta from that link. He must have updated today. I downloaded .977 last week!!
[*] Updated Advances Tweaks databases
[F] Fixed procedure to collect monitroing sources from ATT in "MotherBoard Sources" FlashOSD Plugin.
[F] Fixed current 3D profile detection in non CCC compatible mode
[*] Updated Monitoring Graphs module to support external plugins. This excellent idea was first implemented in RivaTuner by
Unwinder. ATT and RT plugins are incompatible.
[+] Added example Monitoring Graphs plugin "Memory Monitor". Which can monitor global memory statuses like Memory Load %,
Physical memory Available,Page File usage, Virtual memory usage. Source code included.
[+] Added monitoring pluginsd "HDD Temperature". Allows to monitor temperature of HDD disks via S.M.A.R.T.
[*] Updated plugins SDK to support new monitoring graphs plugins
[*] Minor GUI updates
[*] Updated Driver level Overclocking support for RV560/RV570 boards.
[+] Added test support for voltage regulation on X1950XTX boards
[*] Added monitoring plugin "X1xxx Voltages" to provide monitoring sources for GPU/Mem voltages.
Is there any voltage mods available for the x1950pro? because they would be greatly appreciated, I just downloaded the, but they don't seem to do much of anything special that the old ones didn't.
Has anyone got the Saturation slider under the AVIVO tab to work with ATT? Myself and anyone else I have seen post on various message boards hasn't been able to regardless of version or monitor. Using CCC you see results immediately after moving the slider. Under ATT you can move it all you want, hit apply and nothing.
I would really love to get this working as it sure does have things look better. I don't want to have to have CCC installed to get it work however when it should work in ATT.
