D
Deleted member 143938
Guest
How effective is the ATi Tools "Find max core/gpu" feature and it comes to finding artifacts and settings a decent OC? As opposed to running lets say coolbits and futuremark and doing it manually?
For my 8800gt using the auto find option sucks but using rivatuner to OC and using ATITOOL artifact scanner is my favorite combination for achivieving max oc.
So you're saying the artifact scanner is reliable? It seems like a tiny cube, I wouldn't assume it puts more stress on a graphics card than say, CS:S.. does it?
ATITool is a great tool but isnt very good for stability testing.
Last night I noticed my 8800GT was 44C load in Crysis so checked out what ATITool would get and it maxed at 39C.
ATI Tool doesnt push my card near to its max temp.
Oblivion at high res, max detail pushes my card the hardest, getting peaks of 46C under load.
FYI
Weird, if I run ati tools for about 5 minutes my card is at 75c
(I have an Accelero S1 fitted btw)
Well that explains it.
Stupid question: When you run "Scan Artifacts" for ATI Tool, the actual cube doesn't move right? It just stays still and the counter on the bottom just keeps going?
i didn't even know there was a problem?I like very much, except for it's incompatibility with punkbuster. Does anyone know if this will ever get fixed?
What does it do exactly?
I run ATI tool in my tray and use Punkbuster in COD4...no problems that i know about.....
