Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
They are both useful. ATItool can auto-overclock your card a lot better than tray tools, but tray tools can set up your fan to blow more at hotter temps and stuff (atitool might be able to do this but I don't have much experience with ATItool so I don't really know.)
ATi Tray Tools is an all-in-one program for anything from making profiles and settings for certain games to allowing for some overclocking. I had a few issues with some lockups and whatnot but I'm probably just a small few that have this problem. Good program though..
it seems u guys might be a little misinformed about atitool. as far as i know, it can do these thigns:
1. auto-overclock your card (automatically finds max core and mem values without artifacts)
2. manual overlock (input ur own core and mem values)
3. manual adjust fan speed (leave the fan running at 50% all the time, per se)
4. automatic fan speed (throttles fan speed according to gpu temps that YOU fill in)
5. display core temp (also an option to display core temp in tray when minimized)
6. automatic overclock/underclock when entering 3D/2D mode
7. adjust memory timings (although i wouldn't recommend this)
8. more stuff i probably forgot to mention
as far as i know, atitool cannot create specific profiles as MLuke mentioned, that allows for different overclocks in different 3d games which would be a pretty nice option in my opinion
