ATI tool wont save clock frequencies
Ok so im trying to overclock using ati tool instead of ati overdrive which is limited to 700mhz core. Ive already found my max OC at 720 core and 1100 memory (tested with furmark). Now ive set the ati tool to load at startup and to load a certain profile then close. Unfortunately I cant seem to be able to save the profile info. I can create a profile name it, and save it. However I cannot save the clock frequencies to the profile. If I change the sliders to 720 core and 1100 mem then click set clock the sliders just go right back to 0, same thing happens if I click save before set clock as well (the changes do take place though according to GPU-Z). So my question is how do I get ati tool to save my settings
Ah nevermind, its not as stable as I thought at that speed, and the difference between stock and overclocked (700x1100) is almost nil. This leads me to think my Q6600 at 3.3ghz is a bottleneck and since I cant afford to replace it (and dont really want to anyway) im just going to leave the videocards at a level below the ati overdrive limitations.
ati tool has been painless for me, got my 4850 pretty happy these days with auto overclocking and downclocking of my card. i save the hardware overclocking profile and fan profile and seems to work for myself for all the revisions that work with the 4800 series cards. Just ask me and i'll try to help.
