nst6563 said:not sure what ATI tool will tell you, I don't run it and haven't run it in a while. What type of card is it?
Jerunk said:Check the power adapter on the card? Check the pin layout on the bottom? Check the Graphics card slot colour? Does your motherboard support PCI-E or AGP?
holycpu said:dunno how to check hte power adapter on the card.......pin layout as well.......(totally dunno what is it........) my motherboard support PCI-E only.
thats y i want to see if there is some program that tell u
