ATI Tool not detecting my videocard
Whenever I try to "Scan for Artifacts" in ATI tool on my EVGA 8800GT 512, I get this error.
I'm running Vista Ultimate SP1
The Video card you selected for overclocking in ATITool
does not seem to be used by windows
Visial Testing has been disabled.
To fix this, go to Display Properties, Settings, and enable
the monitor output of the card
I'm sure my vid card is rendering windows since there's no visual lag and I'm running Aero w/ no problems.
do you have another video card in the system? onboard video?
are you sure you are using the plug from the back of that video card, not said onboard video?
is all other video devices disabled?
Check my sig. I'm running an IP35Pro which has no onboard video and I don't have any other video card in the machine at this time. The problem completely baffles me. Do you think it could be a Vista incompatibility issue?
