Greetings,
FINALLY upgraded my rig to the specs in my sig. Im using the Omega drivers based off of the Cat 5.1's. Opted for Omega because I do not, never wanted, and never will want the Catalyst Control Center. I haven't OC'd my X1800XT yet. It's cooled with a Danger Den Maze4. No cooling on the memory just yet. it's a new build.
Anyhow, I tried to set a lower 2d clock because I know the card is programmed to run slower during 2d and run at advertised clocks in 3d. Well, I set the sliders down and saved the profile, then went to load it, got some weird things on the screen, and then I had to reboot. Is there a version of ATI Tool out there that will play better with the X1800XT?? I think I'm using version 24 but not sure. I'm in class right now so I can't check. Anyway, anyone been having problems with ATI Tool and their X1800XT???
Could it be the Omega drivers and ATI Tool???? I certainly hope not. I haven't gotten the chance to check max core and memory speed either yet. I'd also appreciate hearing from people with the ASUS X1800XT to see what their max clocks are (preferrably under water). Any suggestions on getting ATI Tool to work right would also be appreciated. I've used ATI Tool before with my 9800 Pro and X800XT with no issues.
Thanks
Thanks
