I have an ATI AIW X800XL (see sig) and I just uninstalled the drivers and updated to Catalyst 6.3. I would like to do away with Cat Cont Center (add/remove programs) and just use the others listed in the title. My questions are:
Should I use ATI Tool or ATI TrayTools or both?
Can I remove CCC without losing anything?
I plan to OC my card slightly. Probably will find out what the max is, then back off half way back to stock settings.
