ATI T200 Unified AVStream Driver issues
liquidfluidity
Just got done building a new system and installing the latest Catalyst drivers. I'm using a X1900 XT Sapphire card. I was looking through the device manager and noticed the infamous yellow exclamation mark at this driver. I have tried reinstalling the drivers but to no avail. Is there a fix for this or do I need to try a different driver?:confused:
Those are the drivers I already have. thanks for replying , though. Do I need to install both sets(all that you linked to) for AVIVO use?
All you need is the first link Catalyst™ 7.7 Avivo™ Suite for X1000 series.. and you'll be GTG!!!
Well , I still have the same issue. I guess I'll have to mail Ati and see what they have to say. Thanks anyway.:(
I had the same issue. So I removed them from Device Manger, reboot the PC, it found the new hardware and prompted me for the path to the driver, gave it the proper path and tada all set for me now... Maybe try that?
or do a right click (Device Manager) and choose update drivers, try automatically first if not, then do the step above. Good Luck!!
Well , nothing has worked. I have did some Googling and I see that there are a few other people with this issue also. Some have just disabled it and never had a problem. I will probably do this until ATI get this straightened out.
I got the automated "how to install..." response from ATI but I am going to follow up and see where this goes. Really starting to erk me! Thanks for the response guys. I will keep you posted on the outcome.
