ATI RS480 NB temp?
tempoct
Hi,
How's your NB temp? Mine running quite hot (on Jetway A210GDMS). Bios reports something at high 50s and get into high 60s when loaded. It is passively cooled though.
Should I be worried? Doesn't seem to have any stability issue though. Slightly overlocked (A64 3200+ @ 2.2GHz).
BTW, how can I read the NB temp in Windows? The included monitor program (MyGuard) doesn't report it.
I am pretty suer every rs480 board has extremly inaccurate temperature sensors. I have a Zalman 7000 AlCu, and my cpu is reportedly in the low 50s idle, and in the ~70s load, which is insanley far off from the real temps (Im using Artic Silver, and im sure I put it on correctly). Same with the NB sensor aswell.
I believe it's up to the board MFG too.
Mine reports CPU at around 45-46 loaded (3200+ @ 2.2GHz). If running at 1.1GHz, it reports low 30s for CPU.
