ATI Radeon Xpress 200
Helis
I'm planning on buying a new computer with an ATI Radeon Xpress 200.(here) I plan on putting this Radeon X800(link) in it. I dont know much about the Radeon Xpress, so i need some help.
My question is will everything work and run together fine and if so will it be decent(for gaming)? Any input would be appreciated. Thanks
yup, it's just an integrated card, your x800 will be fine, it's got a pci-e slot.
No I wont be OCing it Hate...dont know how.
Thanks for the info Tiny although I'm buying it instore at Comp USA $699 for computer and a monitor.
Thanks for the help guys.
Yeah I'm buying an Hp monitor and an Hp printer (which will give me a $50 rebate I think). Hmm now that I look at the same computer from Comp USA's online store It might be cheaper to buy it online with a monitor. Let me do some math to check.
Edit:nm $100 more to buy the monitor and computer online with rebates and everything. Thanks for the help.
I don't think you are understanding.
If you read the rebate itself, it doesn't matter if you buy it instore or not. Read the rebate, you could get more money off even though you buy it instore. I wouldn't buy it online either if I could just drive to CompUSA and pick it up. The link for the online store is just for the rebate link, cause they probably won't mention all the elegible rebates at the store.
This is what part of the rebate says:
You get $50 back, just for buying the computer alone.
No i factored in the rebates ;) . In store they give $150 comp usa rebate and a $100 HP rebate. It's in a newspaper ad so you know they are going to try to make it seem as cheap as possible. I just need to make sure i get everything I need for the rebates when I go instore. Thanks again for all of the help :).
Edit: when I said it will give me a $50 rebate i meant just the printer. Altogether i should be getting $300 in rebates from everything together.
Oh, my bad..sorry.
I don't get an actual newspaper anymore. So I never see the Sunday adds.
Didn't know.
Enjoy your new computer though! They use a good board in it. :)
