ATi Radeon X850 XT PE (PCI-E) overclock issues....
This was top end card in it's heels... All the top end cards don't overclock too well...
That's the best you will get usually... I had a 850xt... That one clocked to 590 core easily... You might be able to squeeze little bit more on the core not so much on the memory...
If you wanted to really overclock more your only other option is to put more volts in it. Google x850 series volt mods and you should be able to find plenty of information.
