howardbob5
- Dec 29, 2006
I purchased a computer with an ATI Radeon HD 4200 video card. Will this be sufficient for running online multi player games such as Black Ops?
a "Source game"? and what game would that be because a 4200 should have zero trouble with any Source game on low settings?Its terrible. I was using one and couldn't get above 20fps in a Source engine game with all the settings on low.
TF2. Couldn't break 20 fps even after turning the settings down.
there is no cpu that would be the bottleneck in a pc that actually comes with a 4200.I suspect that had more to do with the processor inside a computer with an integrated graphics card than it did with the 4200.
You might be able to get some decent gameplay out of it, but you would definitely want to lower the resolution.
well the 4200 is actually a slightly better gpu than the x1300 in some ways.CPU was a 1055T, don't think it was a bottleneck. I was trying to game on the IGP while waiting for my dedicated card to come in the mail.
It's not a bad IGP, seemed fine for general use, but even on older games you'd definitely want to turn down the settings and lower the resolution. Even a $25 discrete graphics card is a solid upgrade from it. I just had some initial shock when I found that games played worse on it than they did on my old Radeon X1300 Pro.
HL 2 will play on nearly any card made in the last 8 years. it will play just fine on an integrated Nvidia 6150 which isn't even close to the ATI 4200. heck I originally played HL 2 in 2004 on an mx440 at 40-60fps on high DX7http://www.youtube.com/watch?v=A32qs5fmEEg
not exactly what I would call a good gaming experience but it does work.
HL 2 will play on nearly any card made in the last 8 years. it will play just fine on an integrated Nvidia 6150 which isn't even close to the ATI 4200. heck I originally played HL 2 in 2004 on an mx440 at 40-60fps on high DX7settings.
