Ati Radeon 9800 AIW
ShepsCrook
Is it worth taking the HSF off of this and putting on some Arctic Silver 5 on the VPU?
It's always worth it to apply AS5. It takes maybe 5 minutes if you do it right and are careful not to spill any on the PCB, and your performance will be better, and possibly you will be able to O/C higher. If you are going to take of the HSF, might as well replace it with a VGA silencer. Easy to install, and a whole crapload better than the Zalman that takes an Act of Congress and 4 Tech support representatives to install. :D
I just might have to look into some of those VGA coolers. The only thing I'm wondering is if the Ati AIW's extra box will block certain heatsinks.
i have a 9800aiw pro with a rev2 arctic vga silencer, and it works fine. upped my max core by 20mhz. but u cannot use the back panel that comes with the cooler so you wont get to attach the fan speed switch to the back of your computer unless you drill a hole or something.
