SultanGris
- May 14, 2006
is it possible to use 3 displays and duplicate two and extend one? the settings seem to indicate so but i cannot get it to work to save my life.
setup, 1 flat screen DVI, one old crt vga but using a DVI adapter which doesnt show up unless i have it plugged into the bottom dvi port, is this my problem? and one LCD tv using HDMI port. I tried going from HDMI on card to my tv and/or my audio receiver, it will not work if all three are plugged in, i can get any two to work just fine, but not all three. any ideas? i want all three! Ideally id duplicate the flatscreen monitor and the LCD tv, as i use my pc for my MAIN TV source and extend the old crt so i can have two minitors in computer room and LCD tv in the other room with wireless keyboard and mouse. driving me insane, is this card incapable of using this setup with these monitors or am i a moron and missing a setting somewhere? do i need to get some of the other connections this card has(forget what they are called but they are tiny, display port or something, got 2 of them) i cannot figure it out, thinking the old CRT might be my weak link though. any info appreciated, thanks.
