ATI Overdrive missing on X1800XT
frankyk
I used to have ATI Overdrive on my X1800XT, then it went missing after I did something some time ago, but I'm not sure what I did to make it go missing. Anyway, how do I re-enable it? I'm in CCC and I don't see the option whatsoever. Do I need to do anything to my hardware or anything or software? I have the latest drivers and such...
Did you disable the hotkey poller? If so you will need to haev it enabled I think for overdrive to be a option
Cat 8.5 was released today. It should be there in the advanced CCC, not the basic. And sometimes when you install a new driver, you need to re-enable it.
I am running nTune and an 8800GTX, but will swap my Crossfire back in tomorrow and take a look if you haven't found it by then.
