ATI Overclocking Utility?
MrGlobe
Hello,
I use a program called nTune, by nvidia, to oc. I had originaly downloaded it to OC my gfx card, but decided not to. I then noticed that i could oc my proc, pcie slot, and ram using the same utility.
My question is, is there a program that works that way for ati cards? I want to oc my mem, proc, and maybe my pcie bus.
Thanks
Globe
only thing that i know ATi has is ATItool but it doesn't allow you to manage your memory/cpu overclock. it's like rivatuner and manages both core/mem speed and monitors temps
I think nTune actually comes with your motherboard because you have an nVidia chipset (at least that's what your sig says).
Here's the page for nTune:
http://www.nvidia.com/object/sysutility.html
You can continue to use it to overclock your fsb, cpu, and PCI-E bus even with an ATI card. If you want to overclock your ATI based graphics card I would suggest ATI Tray Tools or ATI Tool.
I hope that helps.
BIOS OC beats ANY software OC......I use software OC's for fine tuning. BIOS gets me 95% of the way and I use a software OC to attain the speed I need. Make sense.....?
