Here's my situation - I'm using the PC currently in my signature, but I have an 8800gts 320mb laying around. I've been planning to put it in to see how the modded drivers for PhysX works. However, there are a few things I want to clear up.
1 - I know the card draws a lot of power - will there be any issues if perhaps both GPUs are full load? If the 8800gts does not have drivers installed, will it still idle and draw power?
2 - Can you (in Windows 7) change between two GPUs? I know you can install two drivers, but can you toggle which one does the rendering?
3 - If I dual boot with Windows 7 and XP, can you install the 8800gts instead of the 5870 since XP can only use one display driver? This is using the 8800gts in the non-pimary PCI-E slot of course.
4 - Will using a PCI-E 2.0 16x running at 4x bottleneck an 8800gts 320mb? I figure it won't, or at least not noticably, but I'm not certain about this.
Thanks.
Thanks.
