techpriest
- Feb 22, 2008
Just installed a 5970 with cat10.6 + "catalyst profiles update 6/18/10".
Got a few questions:
1. How the hell do I force AA on an individual game (starcraft 2 beta). On my gtx285 I just went to the program settings under 3d and added the shortcut/settings. Is there a 3rd party program that makes things easier?
2. What's the best program to check the temps? On my gtx I just used evga precision to check the temps.
3. Ati overdrive shows only one temp should I be seeing 2 temps since theres 2 cores?
4. What are the max temps? I know this is the Oc version so it should be running hotter. In furmark multi-gpu test I'm getting 93º/94ºc after 10 minutes..
