faugusztin
- Mar 9, 2008
Hi,
i have a issue with my LCD TV (LG 42LC3R) and all ATI products - none of the ATI cards detect the display when connected through HDMI (tested with HD5870 in my secondary PC and HD5670 Mobile in my laptop), VGA is running fine. In short :
How did i come up with this list ?
Now what is the solution for ATI cards, if the display doesn't send valid information, ATI cards doesn't detect the display and i want to use HDMI connection (because of the HDMI audio) ?
Thanks for any ideas (except the most obvious one - replace the LCD TV, that is not a option
- the TV has probably damaged (or somehow incompatible) EDID information for HDMI mode
- it's not the cables
- it's partially a issue of ATI cards
- When i connect the HDMI cable from TV to any of the ATI cards, nothing happens. Display is not detected after connecting or after forcing manual detection.
- When i connect the same HDMI cable from my HP LP2475w to any of the ATI cards, display works without any problems - these two things rule out the cable as the issue. I also tested 2 different cables, same result. Both cables are HDMI 1.3.
- When i connect the LCD TV through the same HDMI cable to my GTX570, display is immediately detected and shows the desktop - true, only at some low mode (1024x768 i think) and have to use a EDID override INF file to use it at native 1360x768 resolution, but the point is that it works.
- When i connect the LCD TV through good old VGA cable, it shows up without any problems, and it does even has the display name "42LC3R-ZH"). So if EDID is damaged, it is probably only the HDMI part?
