ATI Hydravision and Windows 2000 problem
Dizzytt
I have 10 machines that have Radeon 7500 dual monitor cards, with one small problem. Hydravision config comes on anytime a non admin (user) logs in, even if you check do not display again. If you make that person an admin, it won't come back, but if you take away admin rights, then it comes back. Need help! Can't make the users admin (policy).
Please help!
You might make sure that the users have rights to change whatever thing the checkbox changes to turn the hydravision thing off. Make sure that they aren't getting theyre settings from something that has that set (i dont know how you have the rest of your system set up). If you don't need it, and people with only one monitor don't, I would just uninstall hydravision.
They do have multiple monitors, and it is in a command center, where 3 shifts work (multiple people at multiple machines with multiple monitors).
