ebolamonkey3
- Sep 2, 2008
Hi guys, I'm building a budget gaming pc using an AMD 780G mobo and I'm wondering if it'd be better to use a Radeon HD 3450 GPU (since according to my understanding, Hybrid Graphics will only work with HD 3400 series cards) to take advantage of the Hybrid Graphics functionality of the 780G mobo and its integrated HD 3200 chipset or if I should just buy a better card. Since I'm on a budget, a better card would probably end up being a 9600GT (when it goes on sale for $60 ish).
If the hybrid graphics worked with better ATI cards like a HD 3850 or something, I probably would've gone with it, but since the HD 3450 isn't that great performance wise, I'm wondering if it'll be better to just forget about hybrid graphics and go with a 9600GT, even though the 9600GT will cost about twice as much as a HD 3450. Thanks in advance.
