FlangeMonkey
- Sep 11, 2010
Hi,
I'm building a new workstation and my plan is to virtualise it.
My original though was to go ATI R9 290x with ESXi, because of the flexibility of using vt-d/vdga however I cannot ignore the performance, heat and power consumption of Nvidia's GTX 970. The cost is also about the same!
I cannot use the Nvidia in an ESXi solution with VGA Passthough, so I'd be looking at Qemu and a completely different direction than an ESXi deployment.
So the question stands ATI with ESXi or Nvidia with Qemu?
I'm interested in your guys input as well as performance comparisons between the two, because I cannot find any reference material on Qemu's performance.
Thanks,
Thanks,
