ATI equivilent to Nvidia 6800?
aquaragia
I've had the 6800 and want to go the ATI route this time.I really don't need anything extravagant as all I play is C:S Source.What should I get?
Edit: Sorry forgot to say it must be agp
x800GT unlockable (like the 6800) overclockable like a mad man, and sits in like the EXACT same performance segment :D
(why arent you considering a 6800GS?)
Well I'm not going to overclock whatever I get (boring I know) so which is it?
X800 or X800pro or XT?
I have a 6800Gt sitting on AS5 and zalman fan.
I would go for a x800GTO2 or GTO. I know the GTO2 can be unlocked
Newegg has the x800gto2 for 165 shipped
I wouldn't go ATi for an AGP card...
The x800GTO2 is a GREAT card.. sadly it's only PCI Express.
x800XT AGP is a GOOD card.. but only SM2.0b (not SM3.0.. todays standard).
If you have had a 6800 you wont get ahuge performance boost unless you go for an X850XT or so, they are avaiable in AGP not sure on the price though. otherwise maybe you should look into a 6800GT or 7800GS type of card, or even a new cpu/mobo/vcard might be cheaper for you
cards like the X850XT are pretty cheap in PCI-E
