Mar 27, 2004 #1 F fenton06 2[H]4U Joined Mar 28, 2003 Messages 2,140 When I run the Catalyst Installer, the DVD encoder won't install. It says "ATI hardware not found". If anyone has any ideas please help. I'm having problems with my AIW 9200.
Mar 27, 2004 #2 F fenton06 2[H]4U Joined Mar 28, 2003 Messages 2,140 someone has to have had this problem....
Mar 28, 2004 #3 M Myrandex Limp Gawd Joined Nov 4, 2002 Messages 439 Does it do the same thing with the drivers off the CD? Have you tried contacting the manufacturer? Reformat? Maybe RMA time, Jason
Mar 29, 2004 #4 S SodaPopinski n00b Joined Feb 20, 2004 Messages 12 Try manually installing from the CD vice the installer (should be the setup.exe under the DVDDcdr directory). I've seen the install discs not recognize the hardware before and the web updater not recognize the install disc for the DVD codec.
