ATI driver problem with dual display
cheerful
MSI Radeon HD 4350 512MB on XP SP3. Latest ATI driver.
DVI to LCD monitor as primary display at 1280x1024; HDMI to HDTV as 2nd display with extended desktop 1080p. After the TV is turned on and off a few times, I can only have a single display -- if TV is on, it's the TV; otherwise the monitor.
Tried to use Control Panel -> Display -> Settings and got the following message below.
Could any one help to decipher the message and found a solution?
Thanks!
Invalid Display Settings
The currently selected graphics display driver can not be used. It was written for a previous version of Windows, and is no longer compatible with this version of Windows.
The system has been started using the default VGA driver.
Please contact your hardware manufacturer to get an upgraded driver, or select one of the Microsoft provided drivers.
OK
try to force detection of the HDTV, other then that, im out of idea's...
Check the latest release notes for the cat 9.8's, I think they listed something like this as a known bug.
2 things related are posted. But neither says the driver will be corrupted and dual display will be lost
In extended/cloned mode, the secondary display status may appear incorrect in the
"Available Display Devices" page under Catalyst Control Center Basic view
Catalyst Control Center: Hotplugging back a HDMI display might not restore its
original DTV (HDMI) Pixel Format setting, if a DVI display was hotplugged and
unplugged during the interval to the same port
