ATI Cooling Questions
JPGR87
Hi, I have two ATI AGP Cards with broken cooling fans. One is a little 9200 that i use in a basic internet box. The heatsink is really tiny and i'm not sure how long the fan has been broken, but i'm guessing its been long enough that it really doesn't need that big of a fan. Maybe something cheap or a passive cooling solution?
The other card is a Tyan Tachyon G9600 which has a massive blue heatsink that covers half of the front of the card and a lot of the back. I can imagine that this thing needs a little more to stay cool, but it is just a 9600 PRO chipset. I found an Arctic Cooling ATI Silencer 2 for use with 9600pro/xt chipsets, would that be my best bet or should i keep looking? Thanks
If you found that, it will work because the manufaterer of the HSF part said that it is compatible.
