FlamingPanther
- Jan 14, 2003
OK, first some background on my machine, then the problem.
I run Dual KDS RAD-5 15'' LCD panels, and I play a good amount of older games,
and I like to watch dvd's at the same time.
the old games automaticly switch to 640x480, which makes the DVD on the second screen pop, and shift, so to avoid this problem, I set the resolution of both LCD's to 640x480.
now, I installed the new CAT 4.9's, and the control center, (.net 1.1 was already installed, no problems there)
And now, for some odd reason, I can't select 640x480 as a resolution anymore, lowest I can go is 800x600, so I played around with the CCC a bit, and some how turned off one of my LCDs, then the hardware Resolution of my remaining LCD dropped to 640x480, and i'm not sure how I did it (or if I did it at all) but my desktop resolution is still 800x600
and now I can't select 1024x768 (my normal resolution)
anyone have any ideas?
i'm going to try going back to the old Ati control panel.
when that doesn't work, i'll check this thread again.
