Two years ago when I bough a Radeon 8500, I bought it primarly because I hated every minute of the blury picture I had on my CRT from the Abit GF2 MX card I had. Also, ATI was the only one that made ATI cards so it was easy to say that ATI had better analog 2d quality then most NVIDIA cards because they simply used better quality RAMDAC chips (and they all used the same ones). Well now in time, everyone makes ATI cards and of course one is likely to buy a 3rd party version because they are a bit cheaper then the ATI ones.
I have a Powercolor 9700NP which I bought because it was the cheapest version of that card. I have been using using a digital LCD as my primary monitor for the last 18 months so I wouldn't know if it had bad analog quality. Summer or so of last year, I bought a CRT to play games on and serve as a dual monitor. The picture quality of the analog picture is not really that great compared to the digital LCD picture so I am wondering if this 3rd party card has the same downfall as the NVIDIA cards had, the manufacturers use cheap RAMDAC chips. The other possibility is just that I have gotten so used to the non-flicker, great color contrast and clear picture of the LCD that even great analog pictures from CRTs can not compare.
So does ATI specify the RAMDAC chips that all the manufacturers must use or could Powercolor just be using a cheap one and I am right in thinking that the analog quality dropped between the ATI 8500 I had back then and the Powercolor 9700 I have now?
