Alright, my budget's REALLY low. (Hopefully under 600-700 range...)
So far, this is what the computer looks like. (All In CDN funds.)
$69 18" Aqua Black/Silver Case w/Blue Beam Transparent Side Panel 4xFan 350W P4 PS USB 2.0
$79 Western Digital WD800JB 80.0GB 8MB IDE
$119 Asus A7N8X-E Deluxe nForce2 Chipset 5PCI/1AGP8x/3DDR w/Sound GB Lan SATA Raid USB 2.0 Socket A & ATA-133
$105 512MB PC3200 400Mhz 184pin DDR (Kingston KVR400X64C3A/512)
$145 AMD® AthlonXP Barton 2600+(1.91GHz) w/333Mhz FSB 512K Box
$118 NEC ND-2510A 8X4X12 BEIGE DUAL LAYER DVD+-RW OEM W/ SOFTWARE
$37 LiteOn 52x32x52 IDE int CD Writer Retail Box
And for a video card:
$62 ATI Radeon 9200SE 128MB DDR AGP8x w/TV OEM
$65 ATI Radeon 9250 128MB DDR AGP8x w/TV OEM
$83 ATI Radeon 9550SE 128MB DDR AGP8X w/TV & DVI-I OEM
$119 ATI Radeon 9550 256MB DDR AGP8X w/TV & DVI-I OEM
$95 ATI Radeon X300SE 128MB DDR PCI-Express w/TV Sapphire
One of these 5. Which is best for it's price?
Maybe even an x600 if I can fit it in the budget...
Feel free to give suggestions on any hardware, especially video cards.
If you feel one peice of hardware isn't good, lay it on me, help me build a computer!
