Hello all,
I hope someone can help me with this issue. I am stumped.
I have a stable system up and running and receieved the ATI card for Christmas. Go to install it this evening, and I get nothing on boot up. The monitor never 'clicks' on. Even the USB optical mouse won't light up.
I throw my Gainward 4200 in and everything boots up no problem. The issue does not lie with the card as my roommate is currently using it without a single install problem.
Here are my machine specs:
AMD Athlon 2000xp
Gigabyte 7NF-RZ (nForce 2)
512mb Corsair XMS 3200
everything else has been removed..
The motherboard is a budget board. There aren't too many options in the BIOS regarding AGP. I have a feeling that maybe the board is too cheap to support the card. Does this make any sense?
Has anyone had any issues with installing an AIW on a gigabyte board? If so, what methods did you take to resolve it?
Could anyone suggest a board that will be guaranteed to work with the card? I would like to spend < $70 if at all possible.
Thanks!
AMD Athlon 2000xp
Thanks!
