I need to get a new waterblock for my ati/amd 6970 v2.
My original XFX 6970 that I had recently died on me and I was able to rma it and get a replacement from XFX. However, the one they sent back to me is a revision 2 card (since they obviously don't make the originals anymore). My problem is that the waterblock I had on my card (a Koolance AR697) does not fit the version 2 card and I must now find a replacement waterblock.
I have done quite a bit of research over the past few days and have found that there is really only 4 companies I can choose from for this new version 2 card. The following list is what I am trying to get information on:
I have seen many peoples suggestions scattered across the internet, but I am mainly looking for some type of statistics from tests that were performed on these blocks. So far I have only come across Cartago's test results, which tests the v1 variants of the 6970 blocks (and does not include the danger den block) - http://www.techpowerup.com/forums/showthread.php?t=148860. His test results seem to indicate that the Swiftech Komodo has the best thermal performance but it has the worst flow rate.
Based on Cartago's tests, since they are the only statistics I can find, I was leaning towards getting the Komodo but I am worried that the flow rate will affect my cpu temperatures - I have a Koolance CPU-370 cooling a i7-950 and a XSPC RX360 radiator. I was also shying away from the ek block because of the nickel plating issue (not because of customer service, etc.), unless someone can prove it is worth the risk.
So is there anyone who can point me to some other type of tests that were performed on these blocks that I can compare and make an informed decision? I would also love to hear others unbiased opinions on these blocks based on actual performance and experience.
- EK FC6970 v2 (3 varieties - all nickel plated)
- Swiftech Komodo 6900-2 (I cannot find this block. However, it is my understanding that the Komodo 6900 v1 is adjustable and I can replace the VR coldplate to match the v2 model.
- Aquacomputer Aquagratix 6970 type 2
- Danger Den 6970 v2
