ATI AIW 9600xt
aznstyl
I just received my card and installing it rite now. Does anybody have any tips or tricks or overclock advice to get more out of this card for me? Any input is appreciated. Thank you.
If overclock, what program do I use and how to setup so I get the best out of it. Thank you.
I have a 17inc LCD Samsung SyncMaster 710N Monitor. I play little games and mainly movies. My resolution is 1280 x 1024.
then there's no need to overclock your card. Other than that, there's not much you can really do to get more out of that card.
ok, thanks... I'm off to installing it now. Thanks for the fast reply guys.
BossNoodleKaboodle said:
Make sure you set your image quality settings to highest in the drivers and turn AI to low or off.
Where would I go about to do that?
In the control pannel for the drivers, or in the catalyst control center if you're unfortunate enough to be using that.
I've manage to get everything else to work except for the remote control. Anybody know why it doesn't work? I've install the reomote wonder II software but still I can't get it to function right. :confused: :confused: :confused:
