ATI 9800XT too hot?
Carlosinfl
Loves the juice
Ok, I have a bone stock ATI 9800 XT 256MB graphics card I running.
I have not overclocked anything so everything is running as is stock 411MHz.
My question is that when I goto the ATI software, it shows my video card is 66c degrees just running web browser apps and idle.
I feel the card and it feels pretty warm/hot but I am not sure if this is normal.
I don't have a stock cooling fan for this card since it was a test card from work so I bought this thing from Newegg and have it running at the highest speedLink
Should I be worried with these temps on my card or is it made to handdle the heat?
I may be wrong, so if someone knows more, correct me. Yet, I have seen others on this forum running upwards of 80C+ at full load with those cards. So, unless you are breaking well past 80C at load, you are likely OK. I would check the seating of you HSF to be safe. Also, you could try the Arctic Cooler. Works well on my 9800SE->9800Pro OCed beast.
Actually, my 9800 is clocked well past your 9800XT.... Perversely, other than your extra memory, my card is theoretically faster for less than half the price. :D
