chuckm1020
- Jun 12, 2003
Why does it say 411mhz on the overdrive level bar thing. Im thinking that is the core speed, but isnt the core suppost to be at 412mhz on a 9800xt?
Originally posted by woog3150
your card is broken. take it back
Originally posted by LoStMaTt
pffft...newbie cheese^
Originally posted by cornelious0_0
Oh and on a side note, don't bother actually using Overdrive for anything.....the "gains" you're going to see in games will be next to nothing. It's nothing to celebrate over (overdrive).....just another toy to play with.
Originally posted by TsayYote
What do you use to step up your speeds? What do you recommend using, ATiTool, powerstrip etc?
Come on guys, he paid for a 412mhz card. the card is 411mhz. He should, at the very least, return the card. Personally, I would consider a lawsuit.
maybe the card is at 412 mhz and the software is reading it wrong
Come on you guys, you can't POSSIBLY be serious can you??? Listen, nobody has a 9800XT that is 412MHz right out of the box, it just doesn't work that way. It's because they use increments (like I already said) to raise the clock speeds (kinda like a multiplier) and 412MHz is one of those numbers that it almost never lands on DEAD ON. I would seriously hope that a couple of you are just joking around here 'cus you're WAY off. I'd really like to see a lawsuit about that, and how long it takes for ATI to take you seriously and stop laughing their asses off. The software isn't reading it wrong at all.....that's just what it IS.
I'm glad Syphon Filter came out and said this 'cus it's the exact same thing. I can load up CPU-Z when my cpu is at stock clock and what do i see??? 2598MHz.While the cpu clock flucuates during use, the video card clock does not.....but those are two very similar cases. I'd really like to see someone try and sue intel 'cus their 2.6C was booting at 2598.9MHz.
No hard feelings here, I'm just trying to set this straight, 'cus it sounds like there's a few of you that might be slightly confused.
