Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I've Been using the Latest Omega Drivers for my ATI Video Card, but just wondering
what you find for the best performance in Gaming with Half Life 2, which drive do you
use, or consider to be best for the gaming that I'm using, Thank You
I did a lot of searching on other forums, and heard a lot of good things with that
driver, also very good or CS:S, Wahoo, I'm so excited, can't wait to get home
from work and try them out
