ATI 9600pro cooling?
killakale
just picked up a 9600pro and an 8500le (128mb), both for like under $200 cnd (smoking deal, I know ). now im not worried about the 8500, but for my rig i want to overclock that 9600pro, but the cooling is well... sub par to say the least. its the same cooling as the 8500 only the 9600's heatsink is not appoxied on. so its time for a cooling upgrade, i just dont know what to use.
any suggestions?
the only thing that i can find that is said to fit it without modding is the iceburge 4
http://www.vibecomputers.com/index.cfm?loc=iview&if=n&vID=190165
i want to get some good cooling, so i dont need anything that will fit on with out any work, just something that works well.
Thanx guys
stock cooling will get you to 500 core. ram doens't need much.
get some ramsinks if u wanna spend teh cash for 3-4 mroe fps.
I'd suggest Just AS3'ing the core unless you wanna either (have no noise, or Voltmod your card) volt mod will need better cooling.
9600 runs cool even with stock HSF. Save your money unless you want to waste it. ATI has done a great job with the thermodynamics of the new .13 nanometer core. I run mine at 475/ 650 with stock cooling.
that's a 9700 pro
works great :)
