ATI 9600pro cooling suggestions
yeah, if you can mod.
some guy hacked up (kinda, just to make it fit) his stock P4 heatsink (i think?) and put it on his 9800XT to cool it, was pretty cool
it was somewhere on the Vid Card forums, if i find the thread i'll link to it (assuming i look for it when/if i have time).
or watercooling!
any kind of hs will do ya over the stock hsf. I used an old p1 hs and a 60mm amd fan that came with my amd hs. got +10mhz on the core (also applied some thermal compound). now using watercooling --> another 5mhz
