Big Fat Duck
- Jul 5, 2005
hoooooooooooooooooooooooo
i consider anandtech to be pretty reliable
http://www.anandtech.com/video/showdoc.aspx?i=2527
i think this stuff is new:
The available marketing information claims that the GPU uses an "ultra-threaded quad-core 3D architecture" and a "512-bit ring bus" memory controller. For those of you who know a little bit about GPU architecture, the core-quads split the pipeline in the GPU into groups of four (hence the word "quad"). The documentation hints that there are four quads, so expect to see 16 pipes on this card. There are some "confirmations" of 24pp and 32pp, but the roadmaps clearly say four quads (at least to begin with) due to yeild. All signs indicate that a future generation, R580, will use six quads instead. The 512-bit ring bus actually excites us the most; Cell's Elemental Interface Bus (EIB) uses a 16-byte wide quad ring bus, capable of transferring 16-bytes per cycle to the various SPEs. R520's ring bus would actually be four times wider than the bus found on Cell; though this implementation is in R520's memory controller rather than the PPE-to-SPE interface. With all the hype for R520 so far, everyone is banking on the memory controller to put X1800 ahead of R520.
Other interesting technologies on R520 include Shader Model 3.0 (and thus HDR), Adaptive Anti Aliasing, and up to 512MB of GDDR3 memory. Our sources indicate that only the Crossfire versions of X1800 will support 512MB initially, but this may change further downstream. Radeon X1800, X1600 will also feature ATI's Avivo(TM) technology, which we currently cannot discuss further. There was also indiciation in the roadmap that this generation of ATI cards will be supported in Vista.
