thaddyusmaximus
- Jun 3, 2008
I'm wondering if anyone is experiencing the same issues i'm having or know of a solution to them. I'm using the DVI-HDMI Dongle that came with the video card. Any help is greatly appreciated.
System:
Vista Ult 64 bit
Q9550
ASUS P5EVM
4GB RAM
2X150GB Raptor
VisionTek 4850
52" Sharp Aquos
1st issue:
When I switch inputs from the PC HDMI input to another input like component(DirecvTV HD-DVR Box) then switch back to the input of the PC, I would loose audio. The device shows it is working in the Playback properties but no sound is heard. I would have to unplugged the HDMI cable for about 5 secs to get sound working again. I have tried another cable but the issue still persists.
2nd issue:
While the PC is on but the TV/Monitor is on another input. I remote desktop to the PC then disconnect then switch back TV/Monitor back to the PC HDMI Input there will no longer be Video Sync. Unplugging the HDMI cable does not help in this situation. Issue only occurs after logging in via remote desktop.
System:
Vista Ult 64 bit
Q9550
ASUS P5EVM
4GB RAM
2X150GB Raptor
VisionTek 4850
52" Sharp Aquos
1st issue:
2nd issue:
