Ati 4850 Blue Screen
ssg10587
Hi just was wondering if anyone had a similar problem with an ati 4850. I start the computer up and it goes through the xp loading except it doesnt load up the user page instead it goes to a blue screen saying that the driver went into continuous loop or something like that. It mentions ati2diag I think as the problem. It is not too big of a problem as I can restart and it usually works. Any help would be appreciated. Thanks.
You can try safe mode booting and removing the driver with driver sweeper from guru3d or you might check for hardware issues. Mine turned out to be a bad stick giving similar error in vista.
