Athlon XP system issue
GN85
There seems to be a problem with my old Athlon XP system. Windows boots just fine, but the bios always resets the memory frequency to 200MHz instead of 400. When I change it back to 400, hit F10 and Enter, the computer restarts but the the monitor doesn't display anything.
Is this a mobo issue?
...or is it supposed to be at 200MHz and I just forgot?
Ah ok. I coulda swore it used to be at 400. I guess DDR makes it 400 MHz. My bad :/
