Athlon XP Mobo with optical out?
ThyMaster
Hi all, I know of two Athlon XP motherboards on the market with optical out:
Gigabyte GA-7N400 Pro2
Soyo SY-KT600 Dragon Ultra Platinum
Does anyone know any others?
If you are referring to the SPDIF optical in & out, both Asus and Soyo make brackets that attach to the SPDIF MoBo header that provide both co-ax and optical in & out jacks.
My Shuttle AN35N Ultra has the MoBo header to connect to these.
NewEgg used to have the Asus version and Soyo's e-store carries their version.
Biostar used to have a bracket with co-ax and optical out only on it @ NewEgg for $8.00 delivered but I don't believe they are stocking it anymore, though you might find it on a search @ Pricewatch or Google.
Regards, Szandor
Abit NF7 & NF7-S, AN7 too (i think)
The Shuttle SFF boxen all have optical out (SK41G, SK43G, SN41G2, SN45G)
I beleive the MSI nF2 boards come with the d-bracket to give you optical out, the K7N2 Delta-ILSR does for sure, the Delta-L you may have to call MSI and have them ship you one (Same for the micro board)
You can use coax to optical converters with no loss of quality. So you don't have to limit yourself to boards only with optical out.
also the AOpen ultra 400 boards have an optical in/out + SPDIF in/out bracket.
