athlon xp mobile
Xenocide2020
if i were yto get an athlon xp mobile would i need to change any of my other parts or would it just change the chip i was getting
its like a regular chip but mobile.You shouldnt have to change anything but the chip.
Maybe better HSF for cooling, depends on the temps/overclock
you are ready to go if you have a socket A mobo. What mobo do you have?
Because if it is kinda old, it might not support much over 333mhz FSB, im not sure though... :confused:
o yea and do you think a 410 watt PSU will be enough if i want to overclock it to like 2500 mhz or something?
plenty, im going to use a 200watt psu on mine, MN31N micro atx shuttle btw. Im wondering if its enough...
